Compatibility of Evap Coil?
Old 06-02-15, 11:29 AM
haloguy628's Avatar
OK, I did a stupid thing. I installed new humidifier last fall and in process of patching the hole for the old humidifier (installed on the wrong side of the plenum) I drilled hole into the AC evap coil.
I want to just replace the evap coil for right now as replacement of the whole heat/AC system is not viable financially right now. The AC is 5 ton Lennox. Do I have to get Lennox evap coil or can I go with coil from any other manufacturer?
As for the cost can anybody give me approximate estimate as for how mouch I should expect to pay for the coil and the refill? I am in Denver CO area. Thanks.
Old 06-02-15, 11:42 AM
I would have the coil repaired. Is the hole in one of the U copper?
Old 06-02-15, 12:46 PM
Received 25 Votes on 19 Posts
If repairing the coil is not feasible you might check with this company concerning a new coil. They are in your back yard so shipping costs would be minimal.
Evaporator Coils
Old 06-02-15, 01:06 PM
haloguy628's Avatar
Yes, it's one of the U bends. Just want this system to go on couple more years. Then my son will be out of college and I will be in good financial state to get good two stage system.
Old 06-02-15, 01:18 PM
I hear you about college.... That should be an easy fix. Probably take $ 300 to $ 400 in refrigerant. 2 to 3 hours labor.
Old 06-03-15, 03:29 AM
GregH's Avatar
Super Moderator
Received 8 Votes on 8 Posts
It should be an easy repair for a competent trades person.
All that needs to be done is to braze over the hole, evacuate the system and recharge the refrigerant.
You should not have to replace the coil.
