Single pole to double pole contactor exchange
Hi,
Can someone help confirm the wire transfer from a single pole contactor to a double pole? Here is a photo of what i believe would be correct transfer from old to new contactor
Replacing a single pole contactor with a double pole contactor can have an impact on the operaton of the crank case heaters with some manufactures. (Like Carrier)
It looks like you may have a second black wire on 8?
Thanks for the replies.
The angle of the pic just makes it look like there other wires. They are behind the contactor.
You can see it better here. Only one black wire.
