Condensation all around the ac furnace
Old 06-11-15, 04:53 AM
Hi,
I have my ac in the crawl space which has a lot of condensation all around one end of the furnace - exit side. Can someone explain to me what can cause this?
Also what does rebalancing an ac unit mean?
Thank you for your help
Best,
David
Old 06-11-15, 05:50 AM
Geochurchi's Avatar
Received 15 Votes on 15 Posts
I suspect the end that had the condensation on it is the supply duct and may not be insulated correctly,as for balancing that is done buy a professional with specialized equipment that measures duct pressures, and volume of air from the supply registers ,I doubt it is really necessary for a residence.
Geo
Old 06-11-15, 06:53 AM
airman.1994's Avatar
Received 4 Votes on 4 Posts
You need to remove the humidity from the crawlspace. Do you have a vapor barrier? are the vents closed? You must get the RH down.
Old 06-17-15, 06:00 PM
Thanks for the tips.
Any advice on how to insulate the end of the furnace and what to use.
Thanks
