which contactor do I order
I have an old 25 yr old Goodman compresser,CK30-IT,seriel 9706005150,rated at 208/230. The contactor has never been replaced. I do know it a single pole,30 amps/40 I don't know. . System works but it just looks rusted and old. Please advise
I always replace a single pole contactor with a 2 pole contactor . Price difference is small .
If there is physical room / space to do so , U usually go up one size in amperage rating . Again , price difference is small .
God bless
Wyr
God bless
Wyr
I find that many techs always replace a single pole contactor with a two pole contactor. If they wire the crank case heater the same way that it was wired it would never run. If they moved both leads to the L1-L2 side of the contactor it would never turn off.
Carrier does have a backfeed through fan yellow work around on their 5 ton units, but I replace a single pole contactor with a single pole contactor if the old one controlled the crank case heater in this manner.
I am trying to get my head around this , so please bear with me . The CH is wired in parallel around one moveable pole of the contactor ? In series with the compressor wiring ?
How many watts is a CH , typically ?
My impression is the " builder grade " condenser units often do not have CH's ?
Thanks , :-)
Wyr
God bless
Thanks , :-)
Wyr
God bless
According to my calculations , that would be 173.6 watts . At 248 volts . That would be running 24/7 , any time the unit was not running .
An inducement to kill power to the condenser at the end of summer and only restore power a few days before spring start up . On straight A/C
A heat pump has to run in cool / cold weather . It would make sense that they would need a CH even more than a straight cool A/C .
Wonder if my mini splits have CH's ? They are both HP's .
God bless
Wyr
God bless
Wyr
