Condenser fan capacitor question
Old 06-17-15, 12:08 PM
T
I replaced the Capacitor to my fan motor on the external AC unit. When I tripped the breaker back on the fan turned slowly, then gradually sped up to normal operating speed. I turned the unit off then back on with the breaker and it went straight to operating speed. Should I be concerned about the initial start up or is that normal? Thanks,
Old 06-17-15, 12:54 PM
Is it the proper capacitor and good. I have seen them bad out of the box. Also was the motor shaft free.
Old 06-17-15, 01:01 PM
T
Yes it was the proper capacitor. Yes the shaft was free. On a side note the fan had been off for almost a week. I was wondering if maybe it just needs to be oiled. Just thought it was odd on the initial start up to run slow and gradually speed up. But, since that point it seems to be running properly.
Old 06-17-15, 02:14 PM
C
Received 8 Upvotes on 8 Posts
Should not run slow and gradually speed up, something is not right.
Old 06-17-15, 04:48 PM
Received 4,152 Upvotes on 3,729 Posts
I'd keep an eye on the fan as it sounds like a replacement motor may be in your future.
