1968 FEDDERS Package unit replacement
Old 06-20-15, 11:00 AM
Hello again to everyone: Our Air Conditioner is in the attic which looks like a giant
wall unit hooked up to the Return/supply and the Discharge. Electric motor has 2 cages hooked up. My Question: Do AC companies still make this arrangement?
Also, Would someone please tell me if the (2) 60 AMP CARTRIDGE FUSES are too high
of amperage. I am thinking more towards 35-40 AMP.
They are Time-Delay of course. I know it's time for a new one soon as the air out of the registers is somewhat cold, but not blowing strong at all. I will clean the EVAP coils and see what happens. The Filter was just changed.
Thanx for your help
I tried to add some pics/ my first attempt
Old 06-20-15, 12:07 PM
Received 340 Votes on 318 Posts
Sure... package units are still available but that looks more like a split unit.
45 years is a pretty good run for a unit like that.
The size of your fuses is based on the wiring size and the ampacity listed on the ID plate on the unit.
Old 06-21-15, 01:38 AM
Does the fan coil unit have electric resistance heat ? That is my guess . If you do , that is where the majority of the electricity will be required . The fan uses a much smaller amount of electricity , compared to electric heat .
I am guessing the condenser unit is outside at ground level ? Is it still OK ?
God bless
Wyr
