Ac compressor explosion
Old 06-22-15, 07:53 AM
A
Hi
how r u
i got yesterday samsung mini split ac unit
with compressor exploded from terminal cover
exactly one of the terminal has blow up
my question
why a compressor blowup?
Old 06-22-15, 09:40 AM
airman.1994's Avatar
Received 8 Votes on 8 Posts
Hard to say. Wrong voltage? Bad wiring? Bad compressor?
Old 06-22-15, 03:21 PM
chandler's Avatar
Received 6 Votes on 6 Posts
You are in Iraq. What is the nominal voltage and frequency used there? We are primarily a North American forum, so information on what you have may be sparse. Did you get the mini split already exploded? Can you post pictures of it so we can see what you see? http://www.doityourself.com/forum/el...your-post.html
Old 06-23-15, 01:28 AM
A
voltage in iraq is 220 240
frequency 50 hz
i will post pictures later
Old 06-24-15, 08:49 AM
A
here aree photo of the compressor
Old 06-24-15, 09:02 AM
A
and also check this
Old 06-28-15, 10:28 AM
A
any help pal
thank u in advance
Old 06-28-15, 10:30 AM
Houston204's Avatar
Received 17 Votes on 14 Posts
Adding too much refrigerant will cause that problem.
Old 06-28-15, 01:50 PM
A
but i charged it by weight
according to ac plate name
Old 06-29-15, 09:57 AM
A
any more info
thank u in advance
Old 07-02-15, 03:10 PM
chandler's Avatar
If it is already ruined, nothing we can say will fix it. How did you determine the weight of the refrigerant versus what the unit needed?
Old 07-03-15, 09:54 AM
A
i know it cannot be fixed
this unit in service since 2007
it had freon leakage month ago
i fixed it
vacuum the unit
charged te unit it by weight thru electronic scales
coordinating the manufacturer plate name
it worked about 2 weeks perfectly
as i think
if there is add> refrigerant then the unit will not cool perfectly
p.s. the house owner said about hours before the problem happened
voltage supplied was very low
150 volt
Old 07-03-15, 03:30 PM
chandler's Avatar
Well, gee, wow, seems you found the problem after all. Low voltage will burn up compressors all day long. Post #2, Airman suggested that.
Old 07-04-15, 12:14 PM
A
ok
thank u
pleze close the thread
best regards
