Copper Tubing to AC Condenser Covered with Ice
Old 06-23-15, 12:02 PM
The copper tubing going to my condenser unit has frozen over perhaps 2-3 times this year. The last couple of times, I turned off the AC and let it thaw, then turned it back on. What causes that to happen? I've noticed the wrap around the copper tubing has come partially undone. Could this be contributing or causing the problem?
Thanks in advance.
Old 06-23-15, 12:07 PM
airman.1994's Avatar
Received 4 Votes on 4 Posts
Your unit has an issue. Call a repairman. It either has a leak and needs refrigerant or it has a air movement issue.
Old 06-23-15, 12:09 PM
Thank you, airman. We'll give them a call.
Old 06-23-15, 12:17 PM
Air Movement
Think it may be an air movement issue as you suggested, airman. Thought I had changing my filter set up as a recurring event on my calendar. Apparently I didn't recur it far enough out. I'm a couple of months over due for a change. I'll give that a try first after thawing. Thanks again.
