Pull-out disconnect switch (Goodman outside A/C unit will not turn on)
Old 06-27-15, 10:18 AM
So i have a goodman ac unit the outside pull-out ..i guess is the fuse has burnt/ melted at the edges.. So it is not cuttin on ..do a whole box has to be ordered or what do i do please help ...hot
Old 06-27-15, 11:11 AM
Got a picture?
Are you talking about the fused disconnect that get's mounted to the outside wall?
If so any Lowe's Home Depot, electrical supply house will have one.
There not expencive.
Old 06-27-15, 11:48 AM
ray2047's Avatar
Most residential A/C disconnects are unfused (non-fused). Why do you think it is fused? If unfused replacement is only about $6 for the lowest priced. Example: http://www.homedepot.com/p/GE-60-Amp...0RCP/100674085
Old 06-27-15, 12:21 PM
Houston204's Avatar
Almost every pull out disconnect is a little melted at the edges.
Is the fuse good?
Do you have a volt multimeter?
