Dog unplugged control line to outside condensor unit
My dog tripped over and unplugged the line from the thermostat to the contactor and outside unit. I've reconnected the wires but am getting no response no matter what I put the thermostat to. I can turn the unit on manually by pushing the contactor in, the fan blows and the compressor kicks on, but no air blows in the house. I've tried resetting everything by removing power, to the thermostat and to the outside unit and the air handler/furnace inside and it still will not come on.
Help! My landlord isn't responding and I live in Houston- and it is 100 degrees today!
Thanks!
Thanks!
You mean contactor (not capacitor), anyway, try open the T-stat, and jump R wire to Y wire and see if that starts the outside unit, then jump R wire to G wire to see if that starts the inside blower fan.
Hey thanks for the reply. Sorry, you're right. I tried jumping the wires and got no response from either side.
The whole thing was working fine all day yesterday until the dog disconnected the wire.
Now you need to use a multi-meter to find out if you have 24V between R and Y, or R and G, or R and C (while system is NOT call for cool). If you do, then next thing to check is the fuse on the furnace control board.
Fuse
So I got into the furnace control panel, noticed that there was no flashing light (not a good sign). The fuse was indeed blown, and I have replaced it. There is still no activity from the unit when thermostat comes on, and there is still no status light. I've checked my breakers and all are still good.
