Another inop outside condensor unit thread.
Received 0 Votes
Have an approximately 25 year old Amana model arcf48u01d that was blowing cold this morning. Fuses are good inside and out. I can hear a faint buzzing from inside the unit with the power on. Neither the fan or compressor work. Just noticed this tonight and too dark to check anything else. What should I check in the morning? I can check the pressures but since it was cold before, I doubt all the charge would have escaped so quick.
The first thing to check is to see if the contactor is being pulled in and if it is.... is it burned ?
You can turn power off to the outside unit when checking the contactor as it gets its 24vac from inside.
Received 0 Votes
Well, after having everything off overnight I turned it on this morning and the compressor is working but the fan still doesn't.
Received 0 Votes
Checked the voltage of the 3 fan wires at the contactor and capacitor and they were all around 110V so I assume the fan is toast.
While it's certainly possible that the fan is bad, it's also possible that it's just a bad capacitor. Since the capacitor is far less expensive than the motor, I'd suggest that you try replacing the capacitor. Will the fan run if you give it a "push" (try turning the fan with a pencil or stick while power is on)? If so, that's a pretty good indication that the capacitor is bad.
Previous Thread
Next Thread
