AC blows warm air
AC blows warm air
Hello, I have a 7 year old Lennox Elite furnace with the AC and air purification...currently I'm having a problem with the AC. The system works as normal with the settings and everything turns on, but the air that blows is warm air, not cold?
Set the thermostat for cooling and go outside and see if the outside unit is running. Let us know if it isn't running (probably won't be). Do you have a multimeter? If the outside unit isn't running, it will be helpful to help troubleshoot the system if you have one or can borrow one.
