Inside blower shuts off during cooling
So I have a strange issue with my hvac. The inside blower fan works in the on and circ mode when not on cool or heat. When I put it on cool the fan works in the on, auto and circ mode but it shuts off after a few minutes and the compressor/condenser keeps running outside. After a few minutes the blower kicks backs on. I just went down with my multimeter to see what was going on but the blower has been continuously running for the last thirty minutes. I don't know where to go from here. It's a goodman air handler and compressor/condenser. The control board inside the air handler was replaced about 7 months ago (pcbbf112). Any help is appreciated.
Since it appears to be somewhat intermittent (working OK currently), the first thing I would do is to check for loose or broken wires around the thermostat and control board.
Checked for loose wires doesn't seem to be an issue. It's strange that the fan runs no problem when not on cool/heat. Ta managed to drop the house temp 3 degrees in the last few hours. I do notice that the fan does seem to be running on a low speed right now I think? I don't know if it's a multi speed blower or not.
