mini split not keeping room cool
Old 08-11-15, 08:50 AM
P
Needing advice....I just had a klimaire mini split installed.room is 19x16 ft.it's a barn that was converted into an apartment. tin roof and sides. solid 1x4 walls and floor,then paneling and with insulation Mini split is 12k .room is not staying cool. Room has insulation. Should a12k be keeping this room cool? Not sure what other info you need...it's installed. By measurements that came with it.should I call someone else to come check it..besides the guy that installed it? Or do you feel it's working the way it should...? Outside air. In 90s I can set it on 70 and it stays about 75/80 degrees...gets as hi as 87...I have now put an 8k window unit in andi will put it on 70 and it cools it to 70 I have now turned split of, and 8k window unit is keeping it at 71 which is what I have it set on
Old 08-11-15, 11:20 AM
P
Temporarily Suspended
It could be the tin roofing & siding that's limiting the ability, of the unit. You didn't say where you are but if you are in a place like Texas, it could be more, of a problem.
Old 08-11-15, 11:32 AM
Received 1,190 Upvotes on 1,147 Posts
So a 12 K BTU mini-split is not keeping the room cool but, by itself, an 8 K window unit is able to do so?
Old 08-11-15, 11:35 AM
P
Oops, I missed the part about the window unit working.
Old 08-11-15, 03:33 PM
P
Yes.I understand about the tin.but the window unit keeps it very cool at a constant 72 if that's what I have it on..if I turn the window unit off and have ms only on it warms up to 78/80 rapidly. ms is on 64
Old 08-11-15, 04:15 PM
P
I guess that your answer is to use the window unit. I don't know what to tell you about the money that may have been wasted, on the mini split. You might call the company to get an answer.
Old 08-11-15, 05:11 PM
P
Just wondering if anyone couldn't tell me why the w u is keeping it cool, and m s can't keep up..especially since m s is bigger.I don't understand it. thanks for your help
Old 08-11-15, 06:20 PM
P
That's a really good question. Part of AC is removing the hot air. It could be that the window unit is removing the hot air at a better rate. That's just a guess.
Old 08-11-15, 10:01 PM
Received 3,423 Upvotes on 3,069 Posts
Have you asked the installing company your question ?
Old 08-12-15, 10:44 AM
airman.1994's Avatar
Received 8 Upvotes on 8 Posts
Big room for one unit! Id call another company to look at it. With low end equipment you normally get a low end install.
Old 08-14-15, 05:34 AM
P
The guy that installed it has checked it several times...says it's the tin. but that just doesn't make sense to me because of the wu keeping up. He keeps messing with the Freon though. how sensitive it to the amount of Freon that is in it? It had 125 originally.he said he bumped it to 145/150. I was told they are Very sensitive...all I know is I spent a lot of money (for me) on it and am hoping to figure out why it's not cooling...he called and talked to Tec support.but all he tells. me is it's the tin...
Old 08-14-15, 05:40 AM
P
I agree with your theory that the window unit is working & that eliminates the tin as the problem. As I said before, air conditioning has to remove the hot air first & the window unit maybe better at that. The only other thing that I can think of is the position of the window unit is probably lower than the split. Since hot air rises, the split maybe having a hard time.
Old 08-14-15, 07:33 AM
Good point although the problem could be just the opposite.
I've noticed as a rule that the split units do not move a lot of air. I've found that the higher they are mounted the better they work since the cold air gets thrown further.
Old 08-14-15, 07:52 AM
P
So, one way or another, I believe that it's an air movement problem. Chances are slim to none that she can get a refund.
Old 08-18-15, 02:51 AM
jjrbus's Avatar
Received 2 Upvotes on 2 Posts
I wonder what the vent temperature of the mini is vs the window unit?
Old 08-18-15, 06:12 AM
C
Received 5 Upvotes on 5 Posts
What is the delta-T? A mini Split should be around 19-20. Did you said air flow is weak ? that may be your problem. I installed one last year (Mitsibishi 12000), the fan is strong, I can feel the cold air from 10 feet away.
Old 08-18-15, 01:06 PM
a DUCTLESS UNIT SHOULD HAVE MORE AIRFLOW THAN A WINDOW UNIT. Messing with the charge is an issue. This should have been weighed in so it would be exact. Hard to charge these by pressure because of the ramping up and down of compressor and fan.
