Dead Grass Around A/C
Separated from: http://www.doityourself.com/forum/ai...d-ac-unit.html
I have a very similar problem. Grass is dying around my central AC. Grass is dead approx 2 feet from the unit. Very little information is available on the web. I am the home owner so I am positive no herbicide is in play.
The AC unit is an older Luxaire unit. Can the refrigerant, if leaking kill the grass? I recently has a 35 uF 370VAC capacitor replaced after the previous capacitor had a catastrophic failure.
Welcome to the forums.
Not in a perfect pattern like in that picture. Refrigerant escapes as a gas.
I replaced the cap myself. Not very difficult to do. After a conversation with a buddy he thought maybe while the cooling fan was disabled by the bad capacitor that the heat from the unit killed off he grass?? umm, make some sense. Any thoughts?
It literally died within 48 hours of capacitor failing. Rest of lawn is pretty darn good looking, if I don't say so.
Admittedly a weird situation. Thanks for your input but I am going with the theory that while the cooling fan was not working the AC unit heated up enough to damage the surrounding lawn.
Thanks for you interest.
