Bad Run Capacitor - Swollen
Old 09-02-15, 08:00 AM
In short A/C stopped cooling house.
Went outside, noticed unit wasnt running, just humming, no fan spinning.
Gave fan blade a push, it started spinning, went back inside, it still wasnt blowing cool air (although air was blowing of course).
Opened panel, noticed run capacitor swollen.
it is a 3 terminal Run capacitor (Fan, C, HERM) that runs both the fan and compressor (with 4 wires that go to it)
My question: is this just as simple as replacing the capacitor? Does the no cool air suggest another problem???
Thanks guys, great forum!
Old 09-02-15, 09:22 AM
C
Received 1 Vote on 1 Post
If still no cool air after the fan is push started, you have other problems. So you have a bad capacitor and also other issues.
Old 09-02-15, 09:46 AM
Houston204's Avatar
Received 17 Votes on 14 Posts
A swollen capacitor can cause a compressor thermal lockout. Turn off the thermostat so it will cool down by the time you get a new cap.
Old 09-02-15, 10:08 AM
thanks to both replies!
So is there any chance then that just replacing the Cap will fix it??
I was hoping so since it also runs the compressor? If not what else can I check?
Old 09-02-15, 10:26 AM
C
If the compressor was also stopped at that time, the new capacitor may fix your problem. give it a try, capacitor is cheap anyway.
Old 09-03-15, 10:23 AM
W
Both the compressor and the outdoor fan must run for the system to cool ( and the indoor fan ) . Make sure the new dual capacitor is rated the same for the fan and for the compressor and at least as high of voltage as the original capacitor .
If the new cap does not fix it , holler back & be prepared to answer more questions .
God bless
Wyr
Old 09-08-15, 01:37 PM
Hey guys wanted to make sure I checked back in to close this thread,
RELIEF!!!!
Replacing the dual run capacitor (around 40 bucks), brought the AC back to proper running state
BIG THANKS to: clocert, Houston204 and WyrTwister
again, Great Forum!!!
One note however, found it hard to find a supplier that sold these things. Anyone else have this experience? Where is a reliable place/way to buy parts like this? Are these things just ordered on internet nowadays??
Thanks again everyone.
Old 09-08-15, 05:58 PM
Received 1,323 Votes on 1,223 Posts
They can be purchased at HVAC supply houses. The problem is many supply houses don't sell to customers that aren't in the trade.
Old 09-09-15, 05:01 AM
W
I first check Johnstone Supply , then W W Granger . The company I work for has accounts at both .
God bless
wyr
