ECM 2.3 3/4 motor, can I switch to 1hp
Old 09-02-15, 11:29 AM
Smile ECM 2.3 3/4 motor, can I switch to 1hp
HI
They are out of stock on the GE ECM 2.3 3/4 hp motor everywhere I've check that are new.
What would happen to my A/C and Heat if I switched to 1hp please
THank you
Old 09-02-15, 01:14 PM
Did find one for a little more
I did find one for a little bit more but get here by Sept 14
a two stage motor like this one, which is actually my original, no GE available that I've seen
http://www.columbiaheating.com/page_...e/GET-8068.pdf
Old 09-02-15, 04:17 PM
I've decided that 3/4 hp is only choice , is this a comporable one please
Rheem 51-24375-09
5sme39sc is on my original.
Seems like same
1ph
ECM2.3
3/4 hp
Old 09-02-15, 05:43 PM
Received 5 Votes on 5 Posts
Yes, if course - the 1hp motor will be fine.
Old 09-02-15, 07:55 PM
..........THANK YOU Gilmorrie !!!
Old 09-02-15, 10:15 PM
Red face Please--Are there many replacement choices for my GE ECM 2.3 3/4 hp
It looked bleak for a few days, but now there are a couple options popping up that I'd like to order tomorrow Rheem 51-104305-21,Rheem 51-24375-09 are available at one vendor in less than two weeks.
and another at another which would take 2 weeks longer to arrive
My original says:
GE ECM 2.3
1ph
REL 750 2 stage
60 hz
120 V
rpm is blank
my furnace is a Regal-750 [REL-750f]
I've ruled out module due to some symptoms with the way the fan was shuddering slowly, getting full 120v
Thank you for any info !
Old 09-02-15, 10:46 PM
Ruud 51-24376-27 1 HP Blower Motor with ECM Module is the one that would come later and then I saw this for very cheap??
tempting
5sme39sc is original versus this cheaper 5cme39sL
ECM SPECIAL PURPOSE MOTOR, VOLTAGE:120/240, HERTZ:60, PHASE:1, AMPS:9.6/6.8, RPM:1050, SPEED:VARIABLE, BEARING:BALL, ROTATION:COUTER CLOCK WISE LEAD END/CLOCK WISE SHAFT END, BODY:OPEN MOTOR, MOUNTINGIRECT, SHAFT:SINGLE 1/2" X 3 1/2", FRAME:48. RUUD# 51-24375-04,51-24375-08, 51-24375-00, 51-24375-18, 51-24375-14, 51-24375-09, 51-24375-13, 51-24375-16, 51-24375-15, 51-24375-08, 51-24375-10, RHEEM#:51-24375-03 MFG BOXED
SCL # :
151302
MFG :
GENERAL ELECTRIC
MFG # :
5SME39SL0615
Alt Part # :
51-24375-09
Available Quantity :
5
Old 09-03-15, 09:56 AM
Rheem 51-104305-21 just ordered, and will be programmed and shipped
Rheem 51-104305-21
is apparently blank which will be programmed and then shipped in just a couple days.
Strange how the other place I looked needed 2-4 weeks lead time
