American Standard Fan Motor
Old 09-25-15, 04:45 PM
O
I have an American Standard model 2a7b0024 that has the fan motor locked up. The part# is MOT11049. I'm just wondering if there is a universal replacement that will work for this unit. Everything I'm finding is running around $175 - $200. I just thought that if there was a universal replacement I might be able to get it a little less expensive. Thanks
Old 09-25-15, 05:06 PM
Received 1,029 Votes on 955 Posts
I don't recognize that model number or part number.
I'm assuming this is the outside condensor ?
The model number usually starts with three or four letters.
Old 09-25-15, 05:21 PM
O
Here is a picture of the model # and yes it is the outside unit
Old 09-25-15, 05:36 PM
Your model number is 2A7B0042A1000AA.
I'm seeing MOT-11051 as a replacement. (and it is around $200)
1/4 HP - 200-230Volts - 60/50Hertz - 1.3Amps - 1100RPM Speed - Closed Enclosure - 48Y Frame - Single Phase - CCW Rotation - 1.75" Shaft
One hit I found....
Century 1/4 HP Condenser Fan Motor-FSE1026SV1 - The Home Depot
You're going to need to look at the motor and find the operating parameters in order to ID an aftermarket motor.
RPM, voltage, HP,
Old 09-25-15, 06:08 PM
O
Ok, thank you so much for your help
