Moving my A/C condensor project
Old 10-11-15, 06:52 PM
E
Hi all,
First post, glad I found this site.
I am cutting out the back of my garage and building it barn door style, so I have access to my garage from front and back. My AC unit is a ground unit, the wiring seems easy, the lower part of the harness I figure just go to a home store and get a longer one? Of course turning off the power first.
Then I need to move over the PVC tubes, fairly easy, not sure what these are called, I think they are for the condensation that builds up?
What Im unsure about, is there are 2 copper tubes, one small and one medium size . Are these pressurized? I supposed I'd need some new copper tubing and some "L" elbows? As of now Im not sure where to detach or cut them, Im not touching anything yet....
Any advice would be great. Im hardly moving it btw, mostly just turning it Im trying to gain only about 10" of clearance.
Old 10-11-15, 07:15 PM
Received 1,020 Votes on 946 Posts
Welcome to the forums.
You'll need to call an HVAC company to come in and remove the refrigerant from the system, re-do the piping, evacuate the piping and recharge the system. That is your biggest headache there. Call and get the price on that before moving forward.
Old 10-12-15, 09:47 PM
crabjoe's Avatar
You're not going to be able to do this yourself because you need a EPA 608 to legally handle refrigerant and equipment (vacuums, recovery machines, gauges, etc) to do this... Simple hand tools aren't going to cut it...
