Any veteran techs familiar w/ GE Weathertron systems?
Old 10-18-15, 02:55 AM
I was doing some maintenance on my air handler (cleaning coils, brushing dust off fan vanes, vacuuming debris out). It's a small 1.5T split system w/ the AH in a hall closet. I have a 08 Trane heat pump and a older, but working, Weathertron air handler. After brushing down the fan 'blades' to remove old dust, I turned the system fan on w/ a shop vac stuck in the closest register duct. I thought it might minimize the dust I was throwing into the air. I ran the fan manually for about 10 minutes.
I took a break for lunch and went back to put my panels back into place. I noticed the tstat wasn't 'hot' anymore...no digital display. My fan would not turn on. I checked breakers at condensing unit and closet disconnect...no tripped breakers.
I checked the voltage of the terminals, going in and out, inside the closet disconnect...250v. I check the little fuse in the tstat...not blown.
There is no battery other than a small 5.5v watch type battery and it's permanent, from what I can tell. I can't take a reading on it.
I tried to get a 24v reading at the tsat from the R power line but I get nothing.
Is there any fuse or reset button I don't see in the air handler bay?
It seems odd to have it fail after it worked just prior to that, and from what I read online, there is usually another cause in the system to burn out a transformer. It does have some age on it, and I don't mind changing it out, but I'd like to know what caused it to fail.
Any help much appreciated.
Tim
Old 10-18-15, 03:46 PM
What is the model # on the furnace?
Old 10-19-15, 05:36 AM
Houston204's Avatar
Received 10 Votes on 8 Posts
Many of the older Trane and GE air handlers used a 1CK54 (Grainger #) fuse.
It would have a small plastic black knob on the panel or control box.
Old 10-19-15, 08:33 AM
The cover of the transformer compartment had the wiring schematic, which I have attached. I see no fuses.
Since my new transformer is so much larger than the original, I need to modify the enclosure to accommodate it. I'll try to do that today.
Model of air handler heat is BAY96X1408.
Thanks for the feedback.
Old 10-19-15, 12:17 PM
Received 405 Votes on 381 Posts
It would be a good idea to put an inline 3A or 4A fuse in the secondary of your transformer to protect it in the future.
Old 10-19-15, 04:37 PM
Thanks, Pete
That sounds like a smart thing to do.
I just energized the system w/ the new transformer. Everything seems to be taken care of w/ that fix.
I know this is a generic question re a specific problem, but if, in the future, the inline fuse blows, things to look for would be...
1-voltage drop at disconnect?
2- shorted contactor relay?
3- bad reversing valve?
I'm just trying to connect a blown fuse to a cause, if I'm in that situation in the future.
Here is a pic of the 41 year old transformer. My Weathertron was mfgd in 1974. Safe to say, I got my money's worth out of it and then some.Name:  DSCF5283.jpg
Tim
Old 10-19-15, 04:48 PM
23va is a fairly small transformer. The norm would be 40va.
#1 cause of blown transformer is the thermostat wiring from the air handler to the outside condensor.
#2 is a short anywhere in the thermostat wiring.
#3 is a shorted reversing valve or the valve wiring inside the condensor unit.
#4 is a shorted control board..... very rare.
Old 10-20-15, 12:02 AM
Thanks for your troubleshooting tips. I'll save that info for my maintenance files.
re the VA rating...the picture isn't real clear but I think the original is 35VA. I used a 40VA rated replacement unit, as you suggested. I'll run it a few days and see how it holds up. So far, so good though.
Old 10-20-15, 12:44 AM
Now that I look closer.... I see 35va. So 40 was a good choice on your part. Don't forget a safety fuse and we'll hope this case is closed.
Old 10-21-15, 12:07 PM
I'll get the inline fuse installed. I'll be satisfied, at that point.
Thanks for your help and this board's existence. Case closed.
Tim
