Sporlan TXV factory setting?
The Sporlan FJE-1/2-C valve. I want to set this to the 10F factory setting by the number of turns, without having to run the unit. In my case I have a dual evaporator, and dual TXV's. One is new, The other someone installed without connecting the equalizer, and the adjuster cap is missing, no biggy as it doesn't leak (fortunately) this is a medium temp flower 3 door reachin. It has no SOV's either. Its an old R12 converted to R134a. Just put in a new condensing unit but flushed first with RX 11.
I've seen this info somewhere in the past but cant remember it?
Mid point
Decided to backseat then count the number of turns to front seat then start towards backs eating again but only did half the number of turns. Had to start somewhere...
