Pros and cons for Goodman Heat Pump -
Old 01-18-16, 07:09 AM
Question Pros and cons for Goodman Heat Pump -
I am considering different brand of heat pumps with back up elecric air handler to replace my existing trane with oil furnace back up. This is for 60 X 14 mobile home. One of the web sites gives 354 negatives vs only 94 positives for goodman brand. Please give honest opinions concerning the goodman brand vs others. The goodman models being considered are GSZ14 vs SSZ14. Which of these are the best and why!
Old 01-18-16, 09:23 AM
Nothing wrong with Goodman, have installed many of them. The key is to install them correctly.
Old 01-18-16, 05:09 PM
Houston204's Avatar
Received 95 Upvotes on 88 Posts
I am not a fan of installing an evaporator coil that is one ton larger than the outdoor unit. A matched system is even more important with heat pumps.
As long as they don't try to sell you a 3 ton evaporator coil and a two ton heat pump a Goodman system is fine.
