Air handler runs all the time in heat normal in cool.
Old 02-12-16, 12:30 AM
Hey folks, first thanks in advance for this great resource for help. I have a Goodman air handler ASPF426016BA and a sensi thermostat. In heat mode it runs the fan in the air handler all the time, does not shut off unless i throw the breaker, in cool it works fine, you can hear the thermostat working however the handler is being disobedient. Any advice is appreciated.
Thanks
Jet
Old 02-12-16, 01:54 PM
Is this a heat pump system?
Old 02-12-16, 04:28 PM
Received 4,051 Upvotes on 3,634 Posts
Welcome to the forums.
Can't tell if heat pump by the air handler model. Shows use as heat pump or A/C only.
It sounds like the wire that should be on G is on O/B.
Old 02-18-16, 10:37 PM
Guys I,have a Sensa thermostat on it I'm not happy with it so I'm putting a different thermostat on it tomorrow."
