question on american standard/trane AC
Old 03-26-16, 03:17 PM
D
the issue is to install a START-KIT or not....
searching the forums, i see quite a bit of useful info on the subject but i homing i can find some specific help before dive into into it.
having two new systems installed : AS SILVER 14 (same as trane XR14 i was told), one 2 ton the other 3 ton.
the 2 ton comes with a pre-installed start-kit; for the 3 ton, it is listed as an OPTIONAL ACCESSORY, part BAYKSKT263
q1: why does the smaller unit have a factory installed and not the 3 ton unit?
q2, curiosity aside, if the 3-ton does not come with a factory kit, should i assume it is not needed?
q3. while there is no clear answer on the need, is it a good idea to get one installed anyway? (if i can find the parts, so far no luck)
thanks
Old 03-27-16, 04:19 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
If the system works properly without the kit, there's no need to install one.
Old 03-27-16, 08:55 PM
C
Received 7 Upvotes on 7 Posts
New system does not use START-kit. Are you sure it is a Start-kit ? or may be just a run capacitor.
Old 03-28-16, 01:07 AM
Received 4,050 Upvotes on 3,633 Posts
In addition to that...... installing a kit on there now could void the manufacturers warranty.
Old 03-31-16, 09:07 PM
D
in the installation instructions, the kit is listed as an option....so if the installer ( a licensed pro) installs it per mfr instructions, why would that void the warranty?
Old 03-31-16, 09:11 PM
D
for the 2-ton
a. the specifications state: start kit factory installed
b. there are two capacitors and and extra relay
so it is not just a run cap
in comparison, the 3-ton...
a. specs say : start kit optional
b. there is only one run cap and one contactor
for the
Old 04-01-16, 04:58 PM
Grady's Avatar
If the kit is the factory spec'd part & installed by a Trane/Amer. Std. approved contractor, it should not affect the warranty. Still, I question why you want it if the unit starts without difficulty.
