Placement of A/C compressor next to house
Old 03-31-16, 01:47 PM
D
Received 6 Upvotes on 6 Posts
My son is considering installation of a new A/C system; the house has never had A/C before. He has met with 1 or 2 A/C contractors to discuss installation of a new system. The most likely location seems to be what you see in the attached photo. It would probably be placed just to the left of the basement window. As you see in the photo, the main power line enters the house there. The outside power box is higher up on the wall.
We are wondering how close the A/C unit can be to the house. My son would like to keep it close, perhaps only 18" away. I wonder if that is too close, that it would be too cramped if work needs to be done behind the compressor.
Old 03-31-16, 02:44 PM
A
Received 91 Upvotes on 83 Posts
Lots of systems can be less than a foot away from a wall. The bigger issue is that it can not be in front of an electric meter.
Old 03-31-16, 02:56 PM
Received 3,749 Upvotes on 3,362 Posts
Astuff hit the nail right on the head.
Old 03-31-16, 06:59 PM
Received 128 Upvotes on 113 Posts
Needs to be out away from the drip line of the roof.
How's he going to feel about hearing water dripping on it and ice forming on top of it?
Old 04-01-16, 03:47 AM
Received 800 Upvotes on 703 Posts
Not sure I've ever painted a house where the condenser was more than a foot or so from the wall. Another thing to consider is it's relationship to the window as that would be a conduit to bring in noise while it operates .... might not be an issue with a basement window.
Old 04-01-16, 08:33 AM
A
That's what gutters are for.
Old 04-01-16, 06:04 PM
Grady's Avatar
Received 40 Upvotes on 38 Posts
In the installation manual, EVERY manufacturer specifies minimum clearances. These distances are exactly that, minimums. I like to have the equipment 2' or more from the house for service or repairs.
Old 04-03-16, 09:45 PM
D
Unhappy
That's my view on this.
Astuff:
I attached another photo that shows the electric meter. It's about 41" from the basement window, so I think that allows enough space to put an A/C unit there without blocking either the window or the meter.
Old 04-04-16, 01:03 PM
A
Is that just a gutter or a disconnect to the right of the meter? If anything other than a gutter you can't block that either.
Old 04-04-16, 02:50 PM
It looks like it may need to go to the left of the phone box. I see a dryer vent at the basement window. You wouldn't want the A/C condensor sucking in the lint from that.
Old 04-04-16, 03:47 PM
Tolyn Ironhand's Avatar
Received 812 Upvotes on 684 Posts
To the left of the phone/cable box would be my suggestion. As mentioned the meter and disconnect are required to be kept clear 30" wide and 36" deep. My second vote would be to the right of the dryer vent.
If it can be squeezed between the window and the panel, as you mentioned, I think that would be OK.
