A/C tripping breaker when turned ON
Old 04-20-16, 09:03 AM
Hello everyone,
Let me give a little back story. I purchased a home (2 months ago) for my grandfather who couldnt afford a home. The home was a great deal and was sold as is.
looking at the condition of the unit. The AC unit looks brand new (goodman gsx130301 - 13 seer AC, 2.5 Ton) All wires are hooked up except for the thermostat wires.
I connect the white wire from the thermo to blue common on the AC/ Red wire from the thermo to the yellow on the AC
When i flip the breaker on. It trips instantly. One time the break sparked.
Did i connect the thermo wires wrong?
Maybe they never put freon on this new unit?
My troubleshooting:
Thermo was set to OFF - same issue
wires are tighten on the breaker and the AC unit.
I would love some help as I do not have money to pay anyone. Using my money now to help my grandpa
Old 04-20-16, 09:20 AM
Received 3,990 Upvotes on 3,581 Posts
Welcome to the forums.
We need information as to what you are working on. A make and model are ideal. Pictures are always helpful. http://www.doityourself.com/forum/el...-pictures.html
It's unusual to only find two wires on a thermostat. Is this a manufactured or mobile home unit..... possibly a Coleman A/C ?
What size (amps) is the breaker that is tripping ?
Old 04-20-16, 09:31 AM
I will get the amps here in a few hours.
Sorry for any confusion the thermo has 4 wires (attached the image). I followed those wires and they go to the new furnace I had installed (furnace works). From the furnace 2 wires go out to the AC unit. Name:  IMG_1107.jpg
Make/model of the AC unit is goodman gsx130301
-Residential Home
Old 04-20-16, 05:27 PM
Houston204's Avatar
Received 94 Upvotes on 87 Posts
Red and white are not from the thermostat. They should come from the furnace.
(White from the stat is heat not common)
I would verify that the red wire connects to Y along with the yellow wire from the stat.
I would also verify that white connects to furnace C.
That said, it is unlikely that your low voltage connections are causing a high voltage breaker to trip.
You probably have a shorted high voltage wire.
