Condenser problems, fan won't start.
Old 05-03-16, 08:27 PM
L
So I came home a couple days ago and it was 82 degrees inside. I tried turning the ac system off and on but the condenser would not start at all, I checked on it and it was pretty hot. I have been looking online for remedies and I have tried a couple. First I re-wired the fan motor separately to 220V and it worked fine. Next the capacitor was definitely shot, bulging and had no ohms when tested. So I bought and installed everything back. Turned everything on and was feeling hopeful when the compressor kicked on, I waited but the fan never started.
It is now 85 degrees and I'm losing hope. I might have to bite the bullet and call out a technician. I would greatly appreciate anyone out there that has any advise, or would help me troubleshoot through steps.
Old 05-03-16, 08:58 PM
Houston204's Avatar
Received 94 Upvotes on 87 Posts
What is the make and model of this unit?
Did you install a dual capacitor?
Posting some pictures of your wiring may allow us to offer better assistance.
Old 05-04-16, 04:20 PM
L
Here are a couple pics that will answer your questions.
Old 05-04-16, 04:23 PM
L
And yes, I replaced the capacitor with exactly the same thing. 35/5 uF 370V
Old 05-04-16, 06:00 PM
Houston204's Avatar
I suspect that common and run are reversed.
I see the way the diagram has the wiring. Can we see the actual wire connections?
Old 05-04-16, 06:13 PM
L
Yes of course
and the black is connected to the contactor
Old 05-04-16, 10:35 PM
Received 3,897 Upvotes on 3,494 Posts
That capacitor is wired correctly according to the diagram.
The black wire from the fan motor goes to the opposite side (T2) of the contactor as the yellow wire (T1) to the capacitor.
