Ac is trying to start
Old 05-23-16, 09:12 AM
Z
My ac unit won't start, it makes sound like electricity is going thru and about very 30 sec it trying to start. It also heats up top of ac unit
Any ideas what could it be ?
Old 05-23-16, 10:24 AM
Make and model number would help us out. Both the fan and compressor won't start?
Old 05-23-16, 10:38 AM
Z
The model is Goodman CK24-1B
Yeah they both won't start
Old 05-23-16, 11:56 AM
Received 3,417 Upvotes on 3,064 Posts
Welcome to the forums.
Do you know anything about troubleshooting ? Do you have a volt/ohmmeter ?
When the thermostat calls for cooling there is a contactor that closes inside the condensor. This is a big relay that supplies switched power to the compressor and the fan. You will need to disconnect power to the condensor unit, remove the electrical wiring cover and check the contactor for operation.
The contactor gets 24vac from inside the house so it will work even with the power turned off to the condensor.
When the contactor should be activated...... the plastic piece with the pink dot is what gets pulled in.
Old 05-23-16, 05:54 PM
Houston204's Avatar
Received 75 Upvotes on 68 Posts
I have seen a bad capacitor cause this many times.
Capacitors often swell up on top when they fail. The top should not look like a can of soda left in a freezer overnight.
This example is very swollen.
Even though this example is not as swollen it will read 0 microfarad instead of the correct reading.
Old 05-24-16, 01:17 AM
Z
Thank you for the tip guys I'm gonna check it next day and let you know.
Old 05-29-16, 06:04 PM
Z
I forgot to reply to you guys. The capacitor top was pretty swollen . I had to take it out to really see it . Anyways After I changed capacitor everything works fine
