Sharp Window AC problem
Old 05-24-16, 04:18 PM
I have a Sharp 12,000 btu window Ac model AF-125RX. The fan runs but I the compressor is not running. It was working fine at the end of last season and was stored for the winter in a dry place. The unit is about 3 or 4 years old. Any ideas that someone with reasonable mechanical/electrical skill might try to fix it before throwing it out.
Old 05-24-16, 05:00 PM
I'd start by seeing if the compressor is getting power when it should be running and go from there....
Old 05-24-16, 07:56 PM
Unless I miss my guess..... you'll find the problem to be a defective solder or a defective relay on the control board.
Is it fixable.... yes if you're handy. The A/C will need to be taken apart to gain access to the control board. A service manual would be very helpful and can be purchased online.
If you want free detailed help..... I would require you to take the unit apart, take and post pictures of the control board.
Old 05-25-16, 02:23 PM
As the say in the NFL, after further review... The compressor is running but no cold air. Time for a new unit. Costco Danby 12,000 btu 265.00
Old 05-25-16, 08:12 PM
Ahhhhhh....... the refrigerant has left the building.
