Trane XR13 A/C not working
Old 05-28-16, 01:50 PM
Received 2 Votes on 2 Posts
I know very little about air conditioning but I think I have a problem. We had a few warm days in Connecticut and it appeared my A/C system was working fine but now it seems to be taking a long time to cool. The only cooling seems to be coming from recirculating air and pulling some cool air from the basement. That is to say, the air handler seems to be fine.
I checked outside and my Trane XR13 (installed in 2010) is not operating. I checked the circuit breaker and that's OK. Any thoughts on what it can be and next steps.
BTW, the unit is under our deck. Robins built a nest in a light fixture right over the unit and made a mess. I cleaned it out as best I could without opening the unit up but it's possible some nest material get inside.
Old 05-28-16, 02:57 PM
Hi Tony, do you have a voltmeter?
Old 05-28-16, 03:43 PM
Yes, but not a very good one.
Old 05-28-16, 03:46 PM
Received 345 Votes on 323 Posts
You need to carefully check for 240v AC at the disconnect near the outside unit first.
Old 09-25-17, 08:54 AM
Mine went bad three days ago. This thread has the answer.
http://www.doityourself.com/forum/ai...unit-hums.html
I pulled off the service panel on the compressor, snapped pictures of the top capacitor and took it to our local electric supply house. They gave me a different one with the same specs - ROTON 36-355R3744. I double checked the schematic, making sure that the fan wires went to the fan terminal and the motor to the motor terminal, hooked it up, turned it on, and I was back in business. Cost was $13. I've read that it would be a good idea to replace the other capacitor, will consider that option as well. Happy that the thing works.
Note: The capacitor was not swollen. Here are some specs on the one I replaced:
https://www.tranesupply.com/cpt00977/product/CPT00977
CPT00977 Dual Run Capacitor
CAPACITOR; DUAL, 35/5 MFD, 440V, ROUND, W/O RESISTOR
Old 09-25-17, 09:02 AM
Since this thread is over a year old I'm sure the OP has resolved his problem.
There are a lot of things that can cause the condensor not to run. A defective capacitor is just one.
Defective circuit breaker.
Blown fuse in disconnect (if fused)
Low on refrigerant.
Defective contactor.
An overfull condensate pan.
Thermostat.
