AC furnace blower kick on and off after 5s
Received 0 Votes
I have a goodman awb24-08d furnace.The furnace has been working fine all winter. I recently turned on the A/c for the summer but the fan kicked on for 5s then kick off.I then went to the thermostat and try to manually turn on the fan but the Auto/on switch kick the fan on for 5s then off.If I turn the heat on the fan works perfectly.I just replaced the board control and blower capacitor.I have some pics.In the pic i disconnected NO and NC wire for test.Can anyone help?
http://imgur.com/a/sumPO
As you can see in the wiring diagram in heat mode the fan is started by the heat sequencer and in cooling mode the stat starts the blower. Do you have a voltmeter?
Received 0 Votes
Thanks for replying
I do have voltmeter.In the cooling mode i hear the sequencer kick the fan on and then kick off.Is it not normal?.And i just replaceed new t-stat
Set your stat to call for cooling and put your meter on G and C on the broad. You should have 24 volts.
Received 0 Votes
I checked the volt on C and G on the furnace control board.It showed 28v.It is a little higher than you said 24v.May i have bad sequencer?
Previous Thread
Next Thread
