Replacing very old White Rogers thermostat
Old 06-12-16, 08:17 PM
F
Need helps on replacing a very old White Roger Thermostat please!!!
I am going to replace the existing one (picture-1). As you can see the 2nd picture, 4 wires come out from the wall; White, Pink, Orage(?) and Black. The RC and RH are jumped together on the thermos.
The Pink one is connected to the RH.
The White one is connected to the W.
Name:  White Roger Thermostat Panel - Copy.jpg
Name:  White Roger Thermostat Wiring - Copy.jpg
I'm going to buy this one:
https://www.amazon.com/White-Rodgers...YD034WVBQ4RYTK
Here is the manual: http://www.emersonclimate.com/Docume.../0037-7260.pdf
I have a question about the BLACK and the ORANGE ones; how do I connect the 2 wires in the new one?
Appreciated for any helps!!!
Old 06-12-16, 08:26 PM
Received 3,424 Upvotes on 3,070 Posts
Describe your system.... gas furnace with A/C, gas furnace only, electric heat etc.
Your links do not work but almost any stat should work for you.
White - W (for heat)
Pink/red - Rc and Rh (there's a jumper connecting the two together)
Orange - probably Y
Black - probably G
The terminal the wires are connected to are labeled. The orange and black should be labeled. I can see the labels but can't read them clearly in your low res. picture.
Take a flashlight and check them out.
Old 06-12-16, 08:34 PM
PJ has it...
I can see G clearly as black if you zoom just the right amount. So orange has to be Y.
Old 06-13-16, 05:33 AM
F
Hi PJmax and JJinPA,
You guys are absoulately correcdt. I zoom in and can clearly see the BLACK connects to G, the Orange one connects to Y.
Thank you so much for helps.
