A/C inside unit won't turn on, outside freezes up
Old 06-29-16, 09:41 AM
C
My a/C blower is not working and no air is coming from vents. Outside unit working but freezes up. Any ideas where to start?
Old 06-29-16, 10:26 AM
C
Received 5 Upvotes on 5 Posts
Need more information.. May be thermostat, may be capacitor, may be blower itself, or control board, or may be just a fuse. But don't turn outside unit on without the inside blower running. Did you try 'fan only' mode on the thermostat ?
Old 06-29-16, 10:27 AM
Bob14525's Avatar
Received 59 Upvotes on 50 Posts
The outside unit is freezing up because the blower isn't working. You need to figure out why the blower isn't working. There are two general types of motors used in blowers: PSC (Permanent Split Capacitor) and ECM (Electronically Commutated Motor). If you have a PSC motor, you'll see a capacitor located somewhere near the motor (often mounted on the squirrel cage assembly). In either case, check to see that the motor shaft turns freely (bearings aren't bad). If the motor turns freely, check (or replace) the capacitor if a PSC motor. If you have an ECM motor, it's a lot more complicated and expensive. Let us know what you find.
Old 06-29-16, 10:43 AM
C
The motor turns freely. Tried to jump g an r but on go buzzing
Old 06-29-16, 10:45 AM
Bob14525's Avatar
Jumping G to R removes the thermostat as a potential cause of the problem. Can you give us a complete make & model number for the furnace/air handler?
Old 06-29-16, 10:46 AM
C
It is a tempstar and design have a visible capacitor.
Old 06-29-16, 10:49 AM
C
International comfort
Model# EPM24B15C2
Old 06-29-16, 11:20 AM
C
How do you tell whether it's the board or capacitor without just replacing one or the other.
Old 06-29-16, 01:21 PM
I would change out the cap first,, there are only about $20.
Old 06-29-16, 01:22 PM
Bob14525's Avatar
You would need a multimeter that can read capacitance to test the capacitor. However, capacitors are very reasonably priced. You can probably pick one up for
