Condenser fan not working
Old 07-04-16, 11:05 AM
T
I just purchased this home and the ac fan will not come on. The compressor comes on but the fan will not. I've replaced the capacitor which is a 3 lead dual capacitor. I checked the wiring diagram to make sure wires were connected correctly. The fan fired up initially but seemed to be slow and rotating backwards. It ran for about 5-10 minutes then cut off. After letting it rest for a while it will only start up with a push start backwards. It spins freely forward but will not run forward.
Old 07-04-16, 11:10 AM
Bob14525's Avatar
Received 59 Upvotes on 50 Posts
I can't say for sure, but I would guess that you don't have it wired correctly. Is there a wiring diagram on the inside of the outside unit cover? Or, did you take a picture or sketch a diagram of where the wires went before you took them off?
Old 07-04-16, 11:23 AM
T
There is a diagram on the panel. I also took the wires off and connected them one at a time to ensure I was doing it correctly. Idk if the previous owner did it wrong but I checked the diagram and it seems to be wired correctly.
Old 07-04-16, 12:02 PM
Houston204's Avatar
Received 75 Upvotes on 68 Posts
It sounds like you need to replace the motor.
The new motor may require a different capacitor.
Old 07-04-16, 01:22 PM
T
Thanks. I'll try that. Was hoping that wasn't the problem though.
Old 07-04-16, 02:03 PM
Grady's Avatar
Received 39 Upvotes on 37 Posts
Have you verified the wires to be in good shape & the cap you are using is correct. Just because it's new & the same as you took out, means neither that it's good or the correct one.
Old 07-04-16, 02:22 PM
T
I am using a 35/5UF 440 VAC. Would I need to check the panel or the motor to find out if it's correct?
Old 07-04-16, 02:31 PM
T
I just checked the motor and it says 5.0MFD 370 v cap. So I'm assuming I have the wrong one. Right?
Old 07-04-16, 03:33 PM
Bob14525's Avatar
Usually the motor states what value capacitor it requires. As long as the voltage rating on the capacitor is equal or higher than the original, it's fine to use. The important thing is that the capacitance value (5mfd in your case) is correct. It appears that the new capacitor you're using is correct (assuming you're using the 5mfd side (the "F" terminal on the capacitor).
