HVAC transformer problem
Old 07-16-16, 12:22 PM
2.5 ton mr cool. ac quit working had 120 volt going to transformer 0 coming out. replaced transformer still 0 coming out. wiring diagram says 240 volt going in. am i missing 120 volt or is diagram wrong. it is a 240 system.
thanks
Old 07-16-16, 12:48 PM
Received 1,045 Votes on 969 Posts
Welcome to the forums.
A 240vac A/C normally does not have neutral present which means nothing runs on 120vac.
The transformer should most likely be 240vac in to 24vac out.
What's the make and model it's used in ?
Old 07-16-16, 04:53 PM
its a 2.5 ton mr cool model mcpg30s060m14 its got 1 wire coming from L2 which is a 120 prong. is there a bridge between L1 and L2 to make it 240
Old 07-16-16, 08:10 PM
According to the specs that is a 240v packaged system with gas heat.
That is a 240vac to 24vac transformer.
Manual with wiring diagram on page 42/43.
mrcool/wp-content/pdfs/english/MRCOOL-PackGas-Install-Manual.pdf
