Inside fan blower fails to start occasionally.
Old 07-18-16, 02:17 PM
W
Everything will operate as it should but occasionally the fan will fail to start. If I turn it off reach in and spin the fan then turn it back on it'll run fine for a few cycles. So I ran down and pick up a matching capacitor installed it and it started as it should all day. about 8 hours later the ac attempted to start but the fan just hummed, so I turned it off spun the fan turned it back on and everything ran fine again.
It's never stopped while running and it will start ok 3 or 4 times before failing to start. The fan spins freely.... What should I look at next?
Old 07-18-16, 02:27 PM
Received 1,041 Votes on 965 Posts
Welcome to the forums.
If the capacitor failed to fix the problem then it looks like a motor replacement is in your future. As the motor heats up the bearings start to bind. The motors are permanently lubricated and can't be lubricated again.
Old 07-19-16, 04:37 PM
W
Well poo, the ac was off for 2 days and I went in this evening to turn it on the humming started. Spun the fan and off she went. Could I have the wrong size capacitor?
Old 07-19-16, 07:31 PM
I guess you could have the wrong sized cap. Did you match the new to the old ?
It can be a higher voltage but the mfd rating must be the same.
Old 07-20-16, 06:14 AM
W
I matched it. Guess I need to figure out what fan will fit in there and order one. Thanks for the help.
