Failing ac air handler fan.
Old 08-24-16, 11:21 AM
T
Hey everyone,
I was wondering if a failing ac air handler fan motor would start to show signs of poor performance. Such as not spinning fast enough/not moving air fast enough?
Thanks in advance.
Old 08-24-16, 03:01 PM
Bob14525's Avatar
Received 59 Upvotes on 50 Posts
While anything is possible, usually motors don't slow down. If you have insufficient airflow, the first thing to check is the air filter. Dirty filters can cause a reduction in airflow. Unless you have recently done so, I would suggest that you replace the air filter and see if that makes a difference.
