High super heat, high subcooling, variation in suction pressure
High superheat, low subcooling, variation in suction pressure
Hello forum,
I have a trouble with my upstairs R22 split AC system. I'm not sure if I have a fixed orifice or TXV as the evaporator box is sealed and I cannot peek there.
I got a K-type thermometer and manifold gauge set and measured superheat being 51F and subcooling 7F. Target superheat is 19 to 20F.
Also, I noticed the low pressure side fluctuates between ~55 to 65 every few minutes, high pressure side seems fluctuate less.
Should I add R22 or what might be wrong here? Should I add R22? Can the pressure fluctuation be caused by a bad compressor valves?
Thanks for the help, in advance.
Sorry but we do not offer sealed system advice as you must be qualified and certified to handle refrigerants.
