A/C info
A/C info
can I use refrigerant suction line on a/c condenser that I can pick up that have been already used. they look clean and good.
thanks
thanks
Received 38 Upvotes
It is not advisable. The lineset could be contaminated with oil and other contaminants from the previous usage and even thorough chemical cleaning may not be sufficient.
This forum does not give information regarding work on the closed refrigerant system so please do not ask.
We don't discuss charging methods here.
You want to re-use old refrigerant lines ?
I wouldn't recommend it.
