Condensation dripping from underside of A coil onto blower below
Hello,
We are trying to trace the root cause of water leaking from the base of our indoor HVAC unit. We expected it to be the drain pain so we gave that a cleaning out. All appears to work fine (condensation in pain drains to pipe, flows down to pump, pump hits fill line and sends water out - no leaks along that path) so we took off cover of blower unit underneath and saw that water is dripping down from the interior or underside (?) of the coils - we can see the droplets on the coils. The coils have no sign of ice/freezing. I'm guessing the coils could use a good cleaning but not sure that is what is going on here. Any thoughts?
Thanks!
Thanks!
