Outside unit fan not spinning
Old 09-04-16, 09:05 PM
Y
Help my outside unit fan is not working. Capacitor and contactor both been replace. Everything receiving power. When thermostat set to cool, the outside does not make a noise. What my next step ??
Old 09-04-16, 10:11 PM
Houston204's Avatar
Received 75 Upvotes on 68 Posts
Verify that you do not have a pan full of water under the indoor coil.
Measure for 24 volts AC at the outdoor unit.
If you have 24VAC entering the condenser but do not have it at the contactor it could be a pressure switch or time delay relay if present.
