Disabling one A/C duct/vent
Old 09-05-16, 06:51 PM
Hi Everyone. I'm trying to turn off just ONE vent/duct/outlet (whatever it's called) in a one-story house that has central HVAC. I've closed the vent and closed the flaps, and it's still too cold in that room when the AC is on. Is there a way of simply and safely disabling or whatever it should be called ONLY that one duct/vent/etc.? -- without risking any damage to the rest of the system or the house, for that matter--and in such a way as it can be fairly easily re-activated when needed. Thanks so much for any thoughts on this. Bob
Old 09-05-16, 06:56 PM
Geochurchi's Avatar
Received 18 Votes on 18 Posts
Are there any other registers in the home that could be opened more to help relieve the pressure on that one?
Old 09-05-16, 06:58 PM
Received 380 Votes on 357 Posts
Welcome to the forums.
When you closed the register... did that stop the airflow from that register ?
If it did then it's coming in from the hallway.
Is there a return in that room ?
Old 09-05-16, 08:14 PM
Houston204's Avatar
Received 10 Votes on 8 Posts
That duct may have a damper between the grill and the unit.
Old 09-05-16, 08:33 PM
Received 29 Votes on 25 Posts
They make magnetic covers for them.
