aircon unit no power
Old 09-13-16, 11:22 PM
Mitsubishi SRK13yl-s is the model of the aircond. The outdoor unit has no power.
Old 09-13-16, 11:47 PM
Received 3,422 Upvotes on 3,068 Posts
Welcome to the forums from Malaysia.
You should put Non US for your location in your bio.
This is primarily a North America based website. The unit you posted is not sold or worked on here in the States.
With a split unit system... main power is connected to the outside condensor unit and then a power/control line is sent to the blower unit inside. If you don't have power you need to check for a tripped circuit protection device or a problem at the equipment disconnect if one is used.
