Mini split for garage
Old 09-18-16, 08:22 AM
I want to heat/cool my garage. mini split would obviously be the easiest but i dont want to run it 24/7 i just want to run it when im in there working on my cars.
are the mini splits designed for this?
Old 09-18-16, 12:17 PM
Received 340 Votes on 318 Posts
The mini splits will work for a garage but they are a heat pump system and the heating process is very slow. You will not be able to go out in the cold garage, turn on the split and get instant warmth.
Old 09-19-16, 03:08 PM
May be you can put a portable heater in the garage for the first 30 minutes.
Old 09-19-16, 03:16 PM
if its only going to take half hour to warm up to an okay temp 50 ish degrees im fine with that.
i hear they are super efficient and only cost 20$ a month to run. if thats the case ill leave it on 24/7
Old 09-19-16, 03:23 PM
It's hard to arrive at an estimate as it depends on weather and heat loss.
Garages aren't noted for being well insulated.
If you leave it run 24hrs just set a reasonable recovery time. Recovery could be a few degrees in an hour. After you have the unit you can determine how long to allow.
Old 09-19-16, 05:16 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
If you have gas I'd suggest a gas shop heater and a window A/C.
Old 09-23-16, 05:26 AM
airman.1994's Avatar
Received 4 Votes on 4 Posts
Ductless splits are not created = Make sure you get something that will heat well. The good models will heat to 0 with no capacity loss.
