Is it safe to store a window air conditioner in
Old 10-28-16, 12:12 PM
A
Received 104 Votes on 86 Posts
Is it safe to store a window air conditioner in an area enclosed such as a shed but is not heated and susceptible to freezing temps?
Thanks
Old 10-28-16, 12:30 PM
F
Received 36 Votes on 28 Posts
I hope so. I have a 10,000 BTU/hr. window unit that has been stored in my garage next to the main roll-up door for two, maybe three, years. I don't know if the temperature at that place has ever dropped to below freezing but since my garage has no insulation and the home's furnace is installed in the garage and takes combustion air from the place it IS possible the temperature has dropped that low on occasion.
Honestly, as long as any water was drained from the pan before storage (and it would likely evaporate if it wasn't drained) I see no problem.
Old 10-28-16, 03:35 PM
Received 2,944 Votes on 2,657 Posts
I agree. Nothing for the cold to damage.
By the time it gets cold enough.... any remaining condensate should be evaporated.
Old 10-29-16, 01:50 AM
A
Thanks; appreciate the advice. In the shed they shall go then. I am tired of tripping over them sitting on the floor.
Old 10-29-16, 02:29 AM
ray2047's Avatar
Received 15 Votes on 13 Posts
We never remove our A/Cs here. I've had one hanging out the wall in 20 temperatures and never had a problem. Grew up a few hundred miles upstate where it gets colder and window A/Cs again were not removed in the winter and never a problem.
Honestly seems like making extra work for your self to remove them. They do make window A/C covers that go on the outside.
Old 10-29-16, 02:56 AM
A
Yes, thanks I know they do. The windows are the old type wooden and I wrap them with film on the inside during the winter. Much easier to do that without the a/c in the window. The a/c's are only 5k BTU so easy to pull out of the window and carry.
