Trane inside blower won't run correctly
Old 02-03-17, 08:21 AM
My Trane blower has started to act up. It starts then stops goes backwards, then forward. Never comes up to speed. Here is a video of it acting up.
https://goo.gl/photos/fRxBh3sQ937gk6Gk6 Would this be the controller board?
Old 02-03-17, 10:16 AM
Received 339 Votes on 317 Posts
The problem depends on the type of motor.
A standard PSC type motor could require a new capacitor.
If it's an ECM type motor.... the repairs are more difficult and expensive.
A picture of the wiring where it enters the motor would be a big help.
Post the model number of the air handler too.
Old 02-03-17, 10:23 AM
It's a Trane 4TEE3F31A1000AB. Here are the pictures I have.
https://goo.gl/photos/EXfWsUCET5fQvtAQA
I can get a pic of the motor later today.
Old 02-05-17, 02:34 AM
Houston204's Avatar
Received 10 Votes on 8 Posts
I can't view your video. It just displays invalid perimeters.
You are describing a bad motor module. It is screwed to the end of the motor.
That unit looks new. You may still be under warranty.
Old 02-05-17, 05:20 AM
Bob14525's Avatar
Received 11 Votes on 8 Posts
I was able to view the video, and when the motor runs, you can hear something rattling. I don't know if it's bad bearings, something loose, or if the squirrel cage is rubbing against the housing.
Old 02-05-17, 08:25 AM
Houston204's Avatar
I am able to see the video on my ipad. It does sound bad.
I am still leaning toward the module just because I have seen this so many times.
Does the motor spin by hand when power is removed? ( not necessarily freely)
Is this unit very old? Some Trane units have a 10 year warranty.
Old 02-05-17, 10:50 AM
Looks like manufactured in October 2005. (serial 54147F52V)
