thermostat turns condenser off but not back on
Old 03-15-17, 09:48 PM
A
so tstat was calling for cool but wouldn't start the condenser, could hear a buzz, pushed contactor with screw driver and it sucked in and fired up, running fine. turned off tstat yup disengaged contactor, condenser turned off.
ok, turned tstat back on,condenser won't start back up. i assume it's a tstat wiring problem? does it matter that the coolant lines are not connected?
also there is one disconnected part, was like that when i bought it not sure what it is ? (see pic, thing at top)
any suggestions? thanks guys
Old 03-15-17, 10:19 PM
Received 1,112 Votes on 1,032 Posts
Welcome to the forums.
You're kidding..... right ?
Why would you want to run the condensor without refrigerant lines ???????
Old 03-15-17, 10:36 PM
A
hi thanks for replying
bought used wanted to make sure it actually runs, only had it on for 30 seconds. I take it that it's a bad idea ? lol
Old 03-15-17, 11:00 PM
Yes... that's a bad idea.
There is a low pressure switch that will keep the contactor from pulling in when the refrigerant level is low. That may be the item you mentioned in your opening post.
Old 03-16-17, 05:37 PM
A
thanks I believe the previous owner bypassed that LPS will it be ok like that ?
to wire the LPS is it basically just 24v line goes in one side and out the other ? i've got a blue wire and a brown with yellow stripe wire
thanks for the help I appreciate it
Old 03-16-17, 06:09 PM
R
Received 103 Votes on 97 Posts
Don't bypass things. Don't run it without installing it. Your going to destroy it running the unit like that. The fact that it makes some noise and does something when the contactor closes doesn't prove it runs at all.
I also wouldn't suggest pushing that contactor in manually. Google "Arc Flash" to see why.
