P trap on Fujitsu ductless mini split
Old 05-08-17, 09:08 AM
H
I have Fujitsu Dustless Mini Split system installed in the attic, and the drain line is routed to the waste gas line vent pipe without the P trap. I have asked around most of installers stated that it does not require a P trap. My attic does not have smell of sewer, but just want to make sure that if P trap is required.
Old 05-08-17, 10:31 AM
Curios why they put it in the attic ? I would be more concerned why it is draining into a vent pipe. Sounds like a bad idea to me.
Old 05-08-17, 10:51 AM
Received 1,603 Votes on 1,477 Posts
Agreed.
Above the last draining device, like the sink, is a vent line only. It is not used for water drainage.
How can you have a ductless in the attic.... or is this a finished attic that is being cooled ?
The condensate line for that type of unit is supposed to follow the refrigerant lines and drain water outside.
In the end.... yes... you have to use a trap at that point to keep the air handler from bringing any fumes into the unit from the vent line.
Old 05-08-17, 11:10 AM
H
Thanks. Yeah it's a finished attic. I will put a p trap in there.
