Snake in the A/C unit
Old 05-24-17, 07:25 PM
I turned on the A/C today for the first time this year and soon my wife said there was a loud bang outside where the ICP unit sits. I went out, looked down in there and I see a snake hacked up in a couple places, I assume from the fan blade. After getting rid of the snake, I looked around to see if everything was okay and I see a green wire with a yellow stripe that is hanging from the fan housing. There is also one hanging from the inside wall. I was gonna take the cover off and connect them, but I thought I better find out for sure. I don't want to fry anything. Any help is greatly appreciated. Thanks.
Old 05-24-17, 07:35 PM
Received 3,416 Upvotes on 3,063 Posts
Welcome to the forums.
The green wire is a ground. It may go from the motor to the frame.
We'd need a picture of the other one to help. http://www.doityourself.com/forum/el...-pictures.html
If you can't get a picture.... the model number may be enough.
The biggest problem with something getting into the fan is bending the blades and throwing them out of balance.
Old 05-24-17, 09:46 PM
Same green wire with a yellow stripe. Basically, I'm thinking it was cut in half while the whole snake thing happened. Just wanted to double check with people that know this stuff. I'll try to get a picture in the morning. Thanks again.
Old 05-24-17, 09:50 PM
If you have two green wires with no terminals.... you're probably right.... it got cut.
You can use a butt crimp and crimp them together.
Model TCA048AKC4, there is a tube that goes across with a couple broken tie wraps still on the tube. I figured they were holding the wire.
Old 05-24-17, 09:55 PM
Thanks PJ for the help with what was probably the easiest thing you ever had to answer.
Old 05-25-17, 06:03 AM
airman.1994's Avatar
Received 8 Upvotes on 8 Posts
On your own! You said snake! I'm out!!
