Compressor fan low amperage?
Measure the current draw on my compressor fan. The name plate states it is a 1.9 amp motor. My fluke shows between 1.1 and 1.2 amps when running.
Is this an issue, some things I read says fans should draw their rated amps, others say as long as it doesn't go over evrything is good.
The A/C works, just wondering if the motor is on its way out.
Btw, measured the cap and all readings were good.
